Transmission Fluid Question!
Old Oct 30, 2010 | 12:26 PM
Ahmed's Avatar
Default Transmission Fluid Question!
Hi
Can anyone tell me the name of the exact transmision fluid the 99 S80 takes, and where can I buy it other then the dealer. Because im thinking of replacing the fluid and the filter at a local non volvo shop.
Old Oct 30, 2010 | 04:48 PM
537playing's Avatar
Dexron III or higher
Old Nov 1, 2010 | 01:57 PM
Falasi4's Avatar
I just called a dealer about this since called a non-volvo specific shop about having a trans filter replacement/fluid change done and the dealer said Dex 4 - I'd bet dex3 is fine too but obviously no expert. I thought there were 2 possible tranny's in the S80 I have (2000 2.9). The non-volvo shops I spoke with both asked which tranny mine had.
fyi: dealer said filter was about 28$ and gasket also about 28$ + fluid + labor which sounded like it might not be much more, if any, to have it done at the dealer.
Old Nov 3, 2010 | 11:33 AM
travismail's Avatar
just did mine and it will take Dex III or VI about 12 qts because you can never get all the old fluid out unless one does a repeat flush. the filter should only cost you about $15 at parts store. not a difficult job but messy.
Old Nov 8, 2010 | 10:48 PM
NoLifeTilBoost's Avatar
No tranny issues with my '99 T6 so far on Dexron VI. Drain and fill is about 13quarts. You can get Dexron VI cheap at Walmart (Supertech). I'm all about drain and fill rather than flush. Do a drain and fill, drive for a week or two, do another.
Old Nov 15, 2010 | 12:37 PM
mdblythe's Avatar
Default Transmission Service
Hi, I'm getting ready to service my transmission in my 2000 S-80 and want to make sure I do it right. When checking the level of the ATF what is the best way to check it, do I have the car running? Off? in park or neutral? Thanks for the help.
Old Nov 15, 2010 | 02:59 PM
travismail's Avatar
check with the engine running at operating temp in park. make certain you are on a flat surface.
Old Nov 15, 2010 | 03:57 PM
Here's the level check proceedure from VADIS:
Oil level, checking
Warning! Avoid skin contact with the gearbox fluid.
Note! If the gearbox is over filled with oil, there may be operational problems. The oil must be filled to the correct level.
Note! Oil grade: Only ATF fluid Dexron III (with G-license).
Gearbox oil, Volvo P/N 116 1521-8 (1 litre container), 116 1621-6 (4 litre container).
Checking the oil level
Note! Carry out the following check at an oil temperature of 85° ± 5°C. Go to car communication function group 4. Select the digital display parameter. Select the parameter for the gearbox oil temperature.
Preparations:
-park the car on a level surface
-apply the handbrake
-let the engine idle
-move the gear selector lever to position P
-select each gear position, stopping for five seconds in each position
-move the gear selector lever to position P.
Note! Wait two minutes before checking the level.
Note! Cars with Geartronic gear selector assemblies: P-R-N-D-Man. Do not shift up in the manual positions. Cars with conventional gear selector assemblies: P-R-N-D-3–2–1. Stop for five seconds in each position.
Oil level / temperature
Maximum level hot 85°C± 5°C.
Minimum level hot 85°C± 5°C.
Caution! The oil level must not exceed Hot Max.
Warning! The oil is very hot. Use protective goggles and protective gloves.
Caution! Is the oil level above Hot Max? Extract approximately a half a litre of oil.
Check the oil level.
Continue extracting a half litre at a time until the oil level is below Hot Max.
The oil level must be between MAX and MIN.
Test drive the car
Note! After replacing the gearbox oil/filter, the “Gearbox oil change” counter must be reset. Use VIDA vehicle communication to reset the counter.
Old Dec 20, 2010 | 05:28 PM
mdblythe's Avatar
Default Oil
Is it ok to mix ATF? like topping off the original Dex III with VI? or should everything be completely flushed?
Old Jan 6, 2011 | 05:59 AM
I know this is an older post, but ill respond anyway. I mixed III the existing with new VI without issue about 10K miles ago on my T6
Old Jan 9, 2011 | 12:02 PM
mike1976's Avatar
Default gear box oil change gearbox
i have a 1999 s40 t4 auto it has 182000 on the clock changed the oil cuz it was revving but not going anywere it runs ok know but jumps out of gear 2/4000rpm or duz not change aand revs into the red then jumps out and is starting to leak a little i have a recon gear box should i try and put recon in or let the old one die first
Old Nov 9, 2011 | 02:52 PM
Jim_Penrod's Avatar
I have a 2000 V70 with 182,000 miles and the transmision is slipping and not shifting correctly. so i was going to check the fulid. however I and a shop i stoped at can not find the trany dip stick! is is possile that it is a sealed system. (it is a 5 speed) Thanks
Old Nov 10, 2011 | 11:45 AM
Jim_Penrod's Avatar
Default found it
I found it on the front of the engine between the engine and trany behind a hose and some wires. i feel like a dork. i am glad that no one took the time to answer my post.
huzzsaba
Oct 26, 2015 05:29 PM
dany0212
May 22, 2010 10:51 AM
abranz
Apr 8, 2008 04:33 PM
