Transmission Problems on the Highway
Old Aug 22, 2008 | 08:22 AM
maxibar's Avatar
Default Transmission Problems on the Highway
I have a 99 S80 T6 and just recently the transmission when getting on the highway will not shift to 4th gear. I've tried using it in geartronic mode and manually moving it from 3rd to 4th will not work either. All other gears are fine. Any suggestions on what could be the problem? Thanks.
Old Aug 22, 2008 | 08:29 AM
Default RE: Transmission Problems on the Highway
Do you have a transmission service message?
Old Aug 22, 2008 | 08:30 AM
SkyWriter's Avatar
can you it shift into 4th at lower speeds?
Old Aug 22, 2008 | 08:37 AM
maxibar's Avatar
I'm not getting any error messages. I haven't tried shifting into 4th at lower speeds. I've only tried on the highway, the number registers as 4th gear but I can tell it's still in 3rd. No way it would register 3000 rpms at 70 and take off when I barely touch the gas if it were in 4th.
dcjcdc
Jun 4, 2007 07:30 AM
kaltek
Feb 16, 2006 08:20 PM
danrashba
Jul 27, 2005 10:06 PM
Liz_XC70
Jun 30, 2005 07:56 PM
