Turn over but won't start
Old Dec 11, 2008 | 10:03 PM
reggietre's Avatar
Default Turn over but won't start
Hi guys
I have a 99 S80 and it turns over but it won't start. I have a message in the window ( immobilisation activated alarm status on ).
Thanks in advance
Rej
Old Dec 11, 2008 | 10:20 PM
Default RE: Turn over but won't start
That means there is a problem with the Immoblizer. Do you have another key you can try?
BTW I am moving this to the S80 section where it should be.
Old Dec 12, 2008 | 11:43 AM
reggietre's Avatar
Hello tech
Thanks for your quick response. I tried the second key and used it to lock and unlock the car and in the ignition and when I try tostart it will crank but won't start and it post the immobiliser in the window. Is there anything I can try to at least start it and get it to the dealer. I'm trying to save a tow truck.
Thanks
Rej
Old Dec 12, 2008 | 12:16 PM
Sorry no. The car doesn't see the key is in the ignition.
The antenna ring might be bad or it is something in the Immoblizer itself.
Old Dec 12, 2008 | 06:49 PM
reggietre's Avatar
What if I disconnect the negative from the battery for 5 minutes and reconnect. It may reset the alarm and fix the problem? It's a shot in the dark.
Old Dec 12, 2008 | 06:51 PM
You never know give it a try.
Old Dec 16, 2008 | 06:43 PM
reggietre's Avatar
Tried to disconnect the battery and it did not work. Sending it to Dealer on a tow truck. I'll report when I get it back.
Old Mar 27, 2010 | 08:13 AM
koji1's Avatar
Hi i have similar problem with my s80. Any news from your dealer on what might be causing the problem before i take my car in. Thanks
Old Mar 27, 2010 | 08:06 PM
dcm0123's Avatar
I believe there is a chip in the key. If this is true, make sure you have no other keys on your key ring which have a chip in them. They will interfere.
Old Apr 16, 2010 | 09:20 AM
koji1's Avatar
hi thanks for your suggestion but unfortunately i had to take the car in to the local dealer . He advised that we reprogramme the keys and the car but this did not work and it cost me. He has now said the CEM is busted and i need a new one and another set of keys. Can anyone else tell me what might be wrong before i blow too much money on guess work from my dealer.
Gustav
Nov 11, 2017 01:01 PM
Jerry Balch
1998-2000 model year XC70
Feb 15, 2014 11:51 PM
reggietre
Dec 11, 2008 10:20 PM
exotek
Nov 11, 2008 09:32 AM
pmb
Sep 13, 2006 12:15 AM
