Upper radiator hose
Old Oct 9, 2012 | 08:53 PM
vrhs2011's Avatar
Default Upper radiator hose
Quick question, I ordered a new upper radiator hose since my current one is leaking (slowly). Anyway this might sound dumb, do I need to drain the coolant first then replace the hose??...
Or
Can I just remove the hose & nothing will happen....
Old Oct 10, 2012 | 04:40 PM
Lynn_B's Avatar
If you don't drain the coolant, it will drain itself down to the lowest level that you open up by removing the hoses. Either way is potentially messy, but the mess can be contained somewhat by draining at least some of the coolant via the radiator petcock before removing the hoses.
HTH,
Lynn B.
Old Oct 12, 2012 | 08:50 PM
vrhs2011's Avatar
Thanks!!
I did drain some of the coolant out of the system!!! Replacing the hose itself was pretty self explanatory. What took the longest was cleaning the dried up coolant formations around the leak.
mikeawd850
Nov 30, 2012 02:26 AM
Penny99
May 10, 2011 07:45 AM
VolvoS40S60
Dec 16, 2010 01:15 AM
sdguy
Aug 11, 2010 08:18 PM
dmm
Feb 19, 2009 07:07 PM
