Valve Repair 1999 s80 t6
Old Feb 24, 2012 | 03:51 PM
hickman123's Avatar
Default Valve Repair 1999 s80 t6
I got the head off and am about to start ordering parts. My question is what else to replace i am doing the maintance stuff tb, wb, plugs, tb tensioner. What else should i do that breaks i see they have alot of problems with the pcv system. Also any recomendations for were to get engine parts and what timing belts to use seems like the Volvo ones like to break is there a good after market belt to use? Any other suggestions would be good too. Was planning on getting a volvo head gasket but is there a better one going to get aftermarket bolts i know u should replace them also one broke off down inside the block got it out luckily.
Little info on the car i know they are head aches. Bought it with a miss in cyl 6 no compression let it sit for like 6 months and the timing jumped valves hit the pistions loads of fun. I think it jumped from a mouse nest under timing cover but putting tensioner on it any way. Hope u guys can help thanks in advance.
Old Feb 24, 2012 | 09:41 PM
gabyman97596's Avatar
OEM, Genuine & Aftermarket Replacement Car Parts Online | FCP Euro
You can find kits regarding the timing with all the components and the pcv system too
Old Feb 27, 2012 | 05:05 PM
hickman123's Avatar
I was hoping to get alittle more help with this. Do u guys just use any old part and it just works out fine in these volvos? Is there a preferred brand u guys like or does everyone go to the dealer for there parts?
Old Feb 27, 2012 | 09:17 PM
Fcp sell original or aftermarket replacement i always go there some of the guys also buy from them i personnally recomend them! Havent had any issue so far you could try Volvo Parts, Accessories and Performance Specialist Since 1963
Old Feb 28, 2012 | 07:59 PM
hickman123's Avatar
Thanks for the links.
vol740wa
Jun 12, 2015 05:02 PM
peace562
Feb 20, 2015 07:39 PM
abelyear
Oct 12, 2011 01:49 AM
7antera
Jun 2, 2008 08:00 AM
