vehicle speed sensor please help the wife is pissed
Old Jul 25, 2008 | 05:35 PM
dragonz's Avatar
Default vehicle speed sensor please help the wife is pissed
I have a 99 s80. transmission went out and had aused one dropped in. Took it to dealer for code reset. the codes wont reset.The dealer says it is the vehicle speed sensor. says there are 2. One on thetransmision and one in the valve body. the second is not serviceable and i would have to get anew valve body. Very expensive. Can someone tell me how to change the one on the body. Also can u explain what it does and what will happen if i do nothing. Seems to run fine since the tranny was dropped, shifts nice and smooth no noticable problems.
Old Jul 26, 2008 | 10:16 AM
Default RE: vehicle speed sensor please help the wife is pissed
Do you have a hard time starting?
Old Jul 27, 2008 | 07:41 AM
dragonz's Avatar
Yes and now it wont start at all. It cranks and cranks but wont start. It was taking a long time to start but that has evolved into no start at all. The dealer said my key was bad and cut me two new keys. Started at the dealer no problem drove home and parked. The next morning no start . They tried to reset my codes but it goes right back to showing the urgent transmision service required.
Old Jul 27, 2008 | 07:50 AM
The engine might not be getting a good ground through the transmission.
Old Jul 27, 2008 | 08:13 AM
dragonz's Avatar
How can I check that? I was going to have it towed to volvo monday but cant afford it so anything I can do to avoid that would be great.
Old Jul 27, 2008 | 10:19 AM
In the past I have made a ground wire from a battery cable and ran it from the tranny to the motor.
Old Jul 27, 2008 | 10:24 AM
dragonz's Avatar
Thank u for your time Tech. I sure appreciate it. I will try to rig a ground and see what happens. So you think this has nothing to do with the speed sensor? Or possibly the throtle boddy needing cleaning.
Old Jul 27, 2008 | 10:29 AM
It might have something to do with the sensor but might not. I would try the ground first. I doubt the throttle body. That shouldn't stop it from running.
RomoGuy
Jun 10, 2017 11:08 AM
mtoerner
Sep 21, 2012 09:52 PM
JayP71
Jun 30, 2011 06:54 PM
samuebe
Apr 2, 2010 10:52 PM
soogiedave
Jun 5, 2007 12:19 PM
