Volvo S80 synchronization problem !!
Old Mar 8, 2015 | 03:28 PM
rabee7878's Avatar
Default Volvo S80 synchronization problem !!
Hello ...
Car ... Volvo S80
Year .. 1999
ECU .. Bosch 0261204559 .. 01275781B ... H3.2
CEM .. HW-PN 9452596
The car doesn’t start and loose all keys and synchronization with motor ECU after battery discharge, in motor ECU fault code shown ( No communication with immobilize ).
I try to repair CEM by reading flash intel 28F400 memory and fix it, i make 2 Transponder keys by Tango , also i read internal EEPROM memory motor ECU ST95P08, i make new synchronization between (ECU <==> CEM ) success .. i install (ECU.. CEM) back to the car.
Now when i try to start the car, the engine crank and ruining for few seconds and goes off ... when i check the synchronization code at ECU i get wrong code like this (FFFFFFFFFFFFFFFFFF00) ... i do correct again the wrong synchronization code and write to eeprom back ... when i start engine, it ruining for few second then goes off again ... now i change the other ECU and ECM also i got same result ( wrong synchronization ) (FFFFFFFFFFFFFFFFFF00)
correct synchronization code 57971286433914900400
wrong synchronization code FFFFFFFFFFFFFFFFFF00
any idea to hlepe me to solve this puzzle , maybe someone can make it immo off for me >>>
File Type: zip
Old Dec 16, 2020 | 03:57 PM
Houssemeddine Ben Ayed's Avatar
Originally Posted by rabee7878
Hello ...
Car ... Volvo S80
Year .. 1999
have same problem engine crank but no start
Snyper Cyrus
Nov 6, 2020 06:07 AM
bit_eimer
Jun 11, 2017 10:09 PM
Mi6on
1998-2000 model year XC70
Jun 29, 2013 03:17 PM
edwin.dario
Sep 25, 2010 06:18 AM
johnnyocc
Mar 6, 2010 09:05 PM
