ecu programming question
Old Aug 22, 2005 | 09:51 PM
bit_eimer's Avatar
Default ecu programming question
Hi all,
[First, sorry about posting this on the C70 board by accident]
I'm new here and have a 2001 V70 T5 with a slight problem. My ecu has been acting up (got wet) and although it drives fine, my local (non-dealer) service guy can't keep the "urgent engine service required" light to stay off. In other words, the ecu has some kind of intermittent problem that keeps turning the light back on.
So, I bought a used ecu on ebay from a wrecked 2001 V70 T5 (with matching Bosch numbers). But my local Volvo dealer is telling me that they cannot "program" this used ecu to work in my car - that I would HAVE to buy a new ecu.
This sounds very suspicious to me, given that a Volvo dealer is able to sell you a replacement key (with embedded transponder) and program your ecu to accept that new key.
So what the deal? Am I just being fed a line by a dealer who either 1) doesn't know how to do what I want or 2) wants to sell me an $1100 ecu?
Thanks in advance for any help.
And if I should post this to a different catagory, let me know.
...Derek
Old Aug 23, 2005 | 01:34 AM
Default RE: ecu programming question
Once the ECU is programmed to a car it is dead pretty much it will only work on the car it was programmed to.
You can program it to another car.It is a one shot deal.
Old Aug 23, 2005 | 02:58 PM
bit_eimer's Avatar
Thanks for the independent confirmation.
Do you (or anyone else) happen to know what "ties" the ecu to the car? In other words, what keeps it from working in another car?
I believe there is a transceiver in/near the steering column that activates the transponder in the key, receives the key's "megamos" code, and sends that code to the ecu. But there must be another "code" somewhere in the car that the ecu also needs, which is the reason you can't just move the keys and ecu to another car.
Is that other code stored in the transceiver itself?
Old Aug 23, 2005 | 04:04 PM
bit_eimer's Avatar
Just found out that the ecu is "imprinted" with the serial numbers of many (maybe all) of the other computer modules within the car. If these don't match up, the ecu won't operate.
A replacement ecu comes "zeroed" from the factory, and then goes through a configuration procedure at the dealer. The dealer can't do the zeroization, unfortunately.
Old Aug 23, 2005 | 09:06 PM
Thats what I have been trying to say but in different words.
Old May 29, 2017 | 11:43 PM
star393's Avatar
Banned
I believe you meant to say can't and said can and confused people on your statement.
Old Jun 11, 2017 | 10:09 PM
Qurcyuczy's Avatar
บาคาร่า
makaveli2k
Aug 8, 2012 12:32 PM
matt01
Jul 23, 2012 11:12 AM
91shelby
Jun 20, 2011 06:56 PM
bigern45
Aug 5, 2008 08:14 AM
jojoswhip
Apr 30, 2006 05:46 PM
