Volvo S80 Xenon Headlight assembly
Old Jan 9, 2008 | 02:06 PM
woodrows80's Avatar
Default Volvo S80 Xenon Headlight assembly
Would a Xenon Headlight (part #8678111) fit in a 2000 S-80? I want to convert my headlamps over to HID, but don't want to do it with cheap HID bulbs. I also like the look of the true factory Xenon HID headlamp assembly.
Old Jan 9, 2008 | 03:18 PM
S70driver's Avatar
Default RE: Volvo S80 Xenon Headlight assembly
Why don't you purchase an HID kit from SharpHID and be done with it?
Lifetime warranty if you buy the kit with that warranty and great serivce.
The kits are not cheap, they are very well built and worth the money.
Old Jan 9, 2008 | 03:25 PM
woodrows80's Avatar
I have thought about doing that too. I like the look of the factory assembly. If they don't fit, I'll probably go with a kit from SharpHID.
Old Jan 9, 2008 | 03:36 PM
S70driver's Avatar
SharpHID is great. I def. recommend them.
Old Jan 10, 2008 | 01:46 AM
gordon368's Avatar
Actually my xenons burnt out and I sold them(got replacement), I have to say that the temperature that these xenon bulbs run at are HOT, and I believe they damaged my headlight -- now water gets into my headlight. But I used rainX and it is some whatbetter now.
Old Jan 26, 2008 | 04:33 AM
nicolaselias's Avatar
Ive been getting some problems with water in the headlight also, however mine isnt Xenon.. how did the rainx help in this case as Il really like to use it also
thanks
Old Jan 27, 2008 | 10:42 AM
gordon368's Avatar
RainX is designed to bead away water, So you can put it on any glass, majority of the people just put it on the windshield. Pretty much no matter how bad its raining, you dont need to use your windshield wipers (only on high way), So you can put it on any glass surface, so i put it on my headlights thinking it would help/stop water comming in and it did.
Old Jan 27, 2008 | 04:18 PM
Sounds like a nice suggestion Gordon, I think il make a run to walmart this evening and get some..
Just wondering but whats the real point of the headlight wipers? Does water on the light REALLY affect your vision that much? I mean it looks classy but I dont consider it particularly necessary haha
Old Jan 28, 2008 | 07:12 PM
magak2572's Avatar
The headlight wiper/washer activates when the windshield washer is being used. The premise here is that if the windshield needs washing the headlights probably do as well. It is the dirt on the headlight that reduces headlight intensity, not so much the water.
Old Jan 28, 2008 | 08:10 PM
Well I understand that, but stil dont seee the absolute use really...
What kind of work would be required to upgrade to xenons? Would I need a completely new assy or can i simply swap the bulbs? I know its an obvious question but iv never owned a car with xenons... thanks
Old Jan 28, 2008 | 08:14 PM
S70driver's Avatar
ORIGINAL: nicolaselias
Why don't you just upgrade to HID's? Simple and cheaper then you think.
Old Aug 16, 2013 | 11:25 AM
majorcode's Avatar
Can you recommend exact model kit from sharpHID with PN for my Volvo s80 1999? Cheers!
Old Apr 27, 2015 | 11:01 AM
markusdt's Avatar
Default Ugraded to Xenon HID, now getting fault message
I upgraded my low beams to a xenon HID system on my 2000 S80, and now I'm getting a fault message every 20 to 30 seconds for failed headlights. Is this a common problem? I love the brighter lighting, but I'm not willing to have a continually locked-in failure annunciator.
Dyna Rider
2001-2013 model year V70
Nov 5, 2012 12:28 PM
sdl92
Nov 2, 2012 01:21 PM
1995Turbo
Sep 29, 2010 08:57 AM
S80 Guy
Aug 27, 2009 06:53 PM
btk_1
Aug 27, 2008 01:39 PM
