VVT oil leak problem solved
Old Aug 11, 2013 | 05:39 PM
Disco2's Avatar
Smile VVT oil leak problem solved
First off I have to say that buying the cam lock tool kit is the best $$$ I have spent. I had an ongoing issue with oil leaking from somewhere around the intake pulley. I replaced the intake cam seal but it was still leaking. (Also did the exhaust cam seal as long as it was apart) Did some searching and found that it was probably either the intake pulley or the O-rings on the pulley. Luckily I found a set of O-rings on ebay (he only has 6 left) and when I removed it, I saw there wasn't one on the back of the pulley. So I put them on, torqued it down and went for a drive. No leaks!! Glad it was an easy fix .... didn't want to buy a new VVT pulley. They're not cheap!
lkatze
Jul 31, 2023 12:07 PM
Spaz
Jul 5, 2013 08:01 PM
jcjcrespo
Jul 5, 2013 07:50 PM
Hopper
1998-2000 model year V70
Sep 15, 2012 10:48 PM
kartman01
Dec 20, 2005 11:49 PM
