water leak from cabin air filter housing
Old Oct 4, 2008 | 06:05 AM
sato's Avatar
Default water leak from cabin air filter housing
2002 S80 2.9L. when driving in rain few drops water leaks from the housing of cabin air filter under the passenger side dash board. The cabin air filetr was wet and the bottom black cover of the filter housing was also wet. How to trace this leak ? where is the cabin air intake ? Is it between the wipers with a plastic grille? Do I have to check any clogged areas for this water leak ?
Old Oct 4, 2008 | 08:28 AM
Default RE: water leak from cabin air filter housing
I believe the intake is in the wiper cowl area.
Make sure all of that is clean. Also does it still do it if you have it on recirc?
Old Oct 4, 2008 | 03:27 PM
sato's Avatar
It only leaks when I drive in rain. Recir setting has no effect. Is it possible to remove the plastic grill between wipers to see any clogging under the grill if it is the air intake location for the cabin air flow. The top of the grill is pretty clean without any leaves. thanks.
Old Oct 4, 2008 | 03:36 PM
That is hard to get out. Does your car have a sunroof?
Old Oct 18, 2008 | 02:26 PM
sato's Avatar
Sorry for being late was out of town. Yes it has sun roof and I checked the roof drains and they are clear as I tested by pouring water in the drain channel on both sides.
Old Oct 18, 2008 | 09:28 PM
HMM this really is a strange one.
This is not a common thing as well.
Is it the original windsheild?
Old Nov 8, 2008 | 04:12 PM
reidjw's Avatar
Tech, please assist with this one. I can get as much as two inches of rain water in the same area. You would think that the leak would be obvious but from the inside it is impossible to find with removing the dashboard. The molding surrounding the wipers looks to be a booger to remove, but I'm convinced that in order to get to the problem it must come off. The windshield is original and the sunroof is not the source.
Old Nov 8, 2008 | 08:17 PM
tower101's Avatar
There are 2 drain pipes for the cowl
http://trademotion62.reachlocal.net/...layCatalogid=0
Make sure they are clear, you can get at them from under the car.
Old Nov 9, 2008 | 07:13 AM
ORIGINAL: tower101
+1
Old Oct 3, 2011 | 05:08 AM
Copley's Avatar
I realize this is an old thread but was the problem fixed? The same thing is happening to my 2004 S80.
Old Apr 12, 2022 | 02:06 PM
machadojd's Avatar
I too am having this issue with my 2004 Volvo S80. I think the air inlet seal has disintegrated. P/N is 31250775 However, i cannot figure out how to get at it
debargha
Feb 24, 2015 10:46 PM
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
nc_volvoman
Apr 2, 2008 10:32 PM
Ahmed
Mar 28, 2008 04:22 PM
