Whistling Noise in S80
Old Oct 28, 2008 | 09:26 PM
Marz's Avatar
Default Whistling Noise in S80
I have been having several issues with my 2002 Volvo (replaced air flow sensor, ABS module, emission air box). I continue to have a whistling sound coming out of the engine area. It starts acting upwhen the engine gets hot; then becomes loud and annoying. I used to be able to make it go away occassionally if I reved the engine; now it will not go away. There is also some pinging that can be heard. If in park or neutral and I hold the RPM's up at a constant level,the RPM'sgauge will start goingup and downand you can hear it miss firing. I had one mechanic said he thinks its coming from the manifold area.
Any help or suggestions would be great. Thanks.
Old Oct 29, 2008 | 07:47 AM
Default RE: Whistling Noise in S80
Next time it makes the noise pull the oil dipstick and see if it stops if it does then the vent box is bad.
Old Oct 29, 2008 | 12:25 PM
Marz's Avatar
Is the vent box the same as the crankcase breather? What should I be looking at cost wise?
Old Oct 29, 2008 | 12:27 PM
I think the job is around $300.00 if you pay to have it done. Yes as in the crankcase breather.
Old Nov 10, 2008 | 04:16 PM
Marz's Avatar
Thanks and that was the problem.
The shop that worked on it are encouraging me to change the timing belt. They said it should be changed after 75,000 miles. Is that a accurate and a necessary repair I must have done? The car has over 109,000 miles on it. Thanks.
Old Nov 10, 2008 | 04:43 PM
I would have it done ASAP you are on borrowed time everytime you start it.
SDozier
Mar 19, 2011 03:43 PM
jsxxx
May 14, 2009 05:26 PM
coolsingh
May 23, 2008 08:17 PM
volvo94404
May 25, 2007 06:49 AM
danielribo
Oct 23, 2005 06:38 AM
