Windshield wiper blades
Old Jan 22, 2011 | 10:10 PM
MaineVette's Avatar
Default Windshield wiper blades
Does anyone have suggestions on replacement wipers? I tried buying a pair of blades at the local auto store, but unfortunately, even though I bought universtial fit blades, they didn't fit properly.
While messing around with them I also noted the passenger side blade is curved and the drivers side has a small wing\spoiler. I'm guessing these are factory blades and that replacing them would be pretty pricey.
Anyone have any suggestions on how to replace the wipers without spending a small fortune? Can I just replace the rubber part with a refill?
Old Jan 23, 2011 | 03:49 AM
nicolaselias's Avatar
Depends where you live, if you happen to live near an advance auto you can buy the Bosch Icon blades on sale from their website, and use a 35% coupon on top of that and then pick up at store.. Use the coupon code BIG15, its $15 off $40 and add it to the already $10
Excellent blades which are worth the cost (if you get them on sale)..
If you are looking to save $$, the Michelin Rainforce or whatever they are called are about $7 or 8 each at walmart and will do the job, but without the frameless design of the bosch
Old Feb 7, 2011 | 03:27 PM
jeff618's Avatar
Arrow trico neoforms
Take a look at the trico neoform beam blades. I actually switched from icons to neoforms quite a while back. They're super quiet and smooth - clean well. They're fairly priced.
Old Feb 8, 2011 | 10:09 PM
dcm0123's Avatar
I had a couple of bad experiences with Anco low end wpier blades. At one time they had an all metal frame but now use plastic.
I had snow and ice build up at the bottom of the windshield which caused the plastic to crack and the wiper to fall apart.
Old Feb 9, 2011 | 06:37 AM
jeff618's Avatar
Arrow
Yeah, so are the Pylons... If you want basic and inexpensive, the basic tricos are still steel. That said, I still prefer the newer beam blades.
Old Feb 9, 2011 | 04:29 PM
Yea, the beam blades wipe so much cleaner.. I have no experience using them in the snow, but the Bosch Icon is easily the best blade I have ever expeienced..
I have also heard that the Valeo blades are excellent.. I know tirerack sells them
Old Feb 10, 2011 | 06:36 AM
jeff618's Avatar
Arrow
Don't know much about the valeos but I actually switched from icons to neoforms - mainly because neoforms don't require adapters like icons to fit the newer-style arms, but also because of price. Been happy and saved some coin along the way.
rspi
Jan 11, 2014 06:22 PM
Dr.JellyFinger
Dec 17, 2011 02:39 PM
Julia Hall
Jun 22, 2011 08:13 PM
Niel
Dec 11, 2007 06:24 PM
robert213
Dec 11, 2005 03:09 AM
