Won’t start
Old Dec 26, 2021 | 07:56 PM
pooky1279's Avatar
Default Won’t start
So I’m driving down the 160 and all of a sudden my car stops the engine and won’t start up again. And the parking brake light is flashing and on the dash it’s saying brake failure park safely. I changed my brakes on the rear. I don’t know how to start my engine and my car has set for 2 weeks
Old Dec 27, 2021 | 11:15 AM
Did you do a code scan/ reset to view and clear the fault codes? What year is your S80. Note on some cars with the electronic parking brake, there is a requires software reset.
The problem may not be related to the brake pads - could be something like a brake pedal position sensor or something in the ABS controller.
See if there's something useful in the diagnostics flow charts:
https://xemodex.com/us/diagnostic-flow-charts/
You should also do two things 1) check battery voltage to make sure there's a proper voltage level in the battery 2) do a complete fault code scan with an OBD2 reader capable of reading ABS codes.
Skinny C. Williams
Oct 16, 2018 07:45 AM
Tanesha Walker
Aug 18, 2017 02:27 PM
vikont
Jun 13, 2011 06:13 AM
kirkgrau
May 19, 2010 02:22 PM
mz1214u
Oct 17, 2005 06:13 AM
