Shift Lever stuck
Old Dec 25, 2010 | 10:07 AM
NCdad's Avatar
Default Shift Lever stuck
My neighbor, an elderly lady who lives next door owns a 1997 S90. She recently encountered a problem when the shift lever would not budge. She started the car and the car would not come out of 'park'. She depressed th shift lock button but to no avail. Somehow someone got it into gear and it is operating now. But I feel this problem may return as the car was not repaired. I have used her car on several occasions in the past. The shift **** already had a problem of occasionally 'popping out' when shifting. Somehow, I feel the two problems are interrelated.
Does anyone have an opinion on this ?
Old Dec 25, 2010 | 05:45 PM
I had the problem in the past. Here is my solution:
http://www.atthetipwebs.com/technolo...ock_repair.htm
Old Dec 25, 2010 | 08:18 PM
NCdad's Avatar
Hello rspi,
Thank you for the instructions.
Old Jun 9, 2023 | 02:02 PM
Slippery's Avatar
Default Stuck shifter fix
the prob is most likely the ignition switch try turning the ignition switch back just a lil bit after you start the car that should do it don't turn it back so far that it turns the car off tho
cadetgubbins@gmail.com
May 14, 2016 04:46 PM
rolling2
May 4, 2011 07:12 AM
act1292
Aug 11, 2010 07:04 AM
VJZ
Nov 6, 2008 04:26 PM
pfoy
Jul 29, 2007 02:43 PM
