1998 S90 wont go over 50mph
Old Feb 18, 2019 | 08:54 PM
Z3ltix's Avatar
Default 1998 S90 wont go over 50mph
I recently bought this 1998 s90 Volvo the previous owner has put a new fuel pump and spark plugs 3000 miles ago ,yet the car still has issues ,the car starts to violently misfire at 50-55mph and wont achieve greater speeds. The engine also kind of shivers once in a while when idealing it will dip for 1 second then return to normal ideal rpm‘s. Does anyone know what may cause this issue? ,and or how much it costs to fix?
Thank you very much
-Z3
Old Feb 19, 2019 | 10:23 AM
most common cause for misfires at speed is weak spark. For cars with direct coil ignitions, I'd start with replacing the coil packs and inspecting the connectors for cracks. For older cars with distributors, I'd do the cap, rotor and wires.
Old Feb 19, 2019 | 10:30 AM
Z3ltix's Avatar
I talked to the previous owner and he gave me some info and said he had it diagnosed and that it would be the cam position sensor but the job it self would be 500$ altho a reliable sensor only costs 60-80$.Maybe it is because there has to be some timing that has to be adjusted or some other tune ups but ill first get that sensor fixed then keep yall updated.
Sage55hunter
Sep 29, 2016 11:15 PM
joelowrider
May 23, 2015 08:48 PM
USFBull56
Jul 12, 2011 05:56 AM
67MercCat
Jan 5, 2011 09:23 PM
