Check engine light
Old Nov 12, 2006 | 12:22 PM
Ched's Avatar
Default Check engine light
Daughter left gas cap loose now I have a CEL. Is there a proceedure to reset this code myself or will a shop have to do it???
Old Nov 12, 2006 | 12:45 PM
Default RE: Check engine light
A shop will have to do it.
The light will eventually go off but the code will still be stored.
Old Nov 12, 2006 | 12:55 PM
Ched's Avatar
thanks. "tech".
If and when the code is cleared will the OBDII "ready" settings be lost as well?
Also , if OBDII settings are cleared will several months of routine driving reset them? On two occasions I needed to change the battery approx 6 weeks before emissions inspection and failed due to OBDII. Dealer cost to reset this is high.
Old Nov 12, 2006 | 11:26 PM
When the light is set the readiness is lost.
But once the code is cleared it should be reset shortly after.
The routine driving should get it to ready in a pretty short time.
Sometimes they can be a pain to get back to ready.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
