Climate Fan on 1998 s90
Old Sep 16, 2011 | 06:21 PM
kens960&s90volvos's Avatar
Default Climate Fan on 1998 s90
Hi. My inside fan doesen't blow on any switch position. Only airflow I get is when moving. There is power to the control unit as the AC will cool as the air passes thru the evaperator when I'm driving (moving). But, when I'm stopped thereis no air flow. I suspect the control unit being bad. Does anyone have anything that may help me? Thanks in advance... I love this site as I have found wonderful and detailed troubleshooting here.
Old Sep 16, 2011 | 09:16 PM
Henry10's Avatar
When in Manual, i.e. turn the Air Direction Selector to upper vents, and turn the Fan Speed **** into all 4 position, does the fan/blower work accordingly? Regardless if idle or in gear.
If no, you need to get to the blower and jumper it. If blower works at Maximum speed (which it should), then you can troubleshoot the Blower Control Module.
Yes, The ECC units are known sometimes to act erratically, basically due to bad solder joints. You can take it out, check it with a magnifying glass and re-solder the cracked joints.
mcintorb
Nov 26, 2012 09:52 PM
nertil1
May 25, 2008 11:30 AM
s40guy
Apr 10, 2007 11:59 AM
edgoss
Dec 7, 2006 10:59 PM
Nemesis
Oct 14, 2004 11:55 PM
