Head Reinstallation
Old Oct 22, 2020 | 02:59 PM
TyBu's Avatar
Question Head Reinstallation
I dismantled the V90 for a head repair. I have all the parts and the manual to do so. However, i spun the bottom crank. I am pretty sure I moved it out of time. My question is, do I need to set the bottom crank to TDC via the markings on the pulley with the markings on the block prior to setting the head? If so, what are the processes to put the bottom crank back into time.
Chiiltons manual #72302
1990-98 Repair manual.
Old Oct 23, 2020 | 06:09 AM
maggs's Avatar
Suggest trying Swedespeed for the answer to your question, as well. https://forums.swedespeed.com/
Old Oct 23, 2020 | 07:23 AM
You can bolt the head on - but don't put the cams in without setting the crankshaft in the correct position - or you will end up with bent valves.
Old Oct 23, 2020 | 02:12 PM
TyBu's Avatar
thank yall both for the helpful information!!
klr650goldwing
Sep 26, 2015 03:25 PM
JimBee
May 27, 2010 08:09 PM
wlfire55
Jan 15, 2010 08:18 PM
gemuth
Feb 28, 2009 08:07 AM
x1sjwebster
Feb 12, 2005 05:33 AM
