Headlight question
Old Feb 5, 2008 | 06:23 PM
rmac2001's Avatar
Default Headlight question
Ok, I know this is a basic question. I've replaced the turn signal light and that makes sense but I don't understand the directions to replace the low beam bulb. Do I need to take the plastic cover off on the outside of the car? There are metal sliders that attach it do I need to move those over- and if so which way? Also, when I went to Auto Zone they recommended buying lightbulb grease. I smeared on the base already and when I read the directions in the manual it mentioned that any grease may damage the reflector- do I need to get a new ungreased bulb.
Thanks for your help.
Old Feb 5, 2008 | 07:05 PM
Default RE: Headlight question
Clean the bulb off.
Look at the back of the light under the hood. There is a cover you need to remove to access the bulb to replace it.
Peter1234
Nov 23, 2010 01:19 PM
snulma1
Oct 5, 2006 11:50 PM
carguyray
Oct 1, 2006 09:22 PM
mladen
Jan 1, 2006 02:41 AM
billy
Dec 28, 2004 11:09 PM
