Problems with my 960/s90
Old Dec 15, 2008 | 07:24 AM
oseyio's Avatar
Default Problems with my 960/s90
Hi,
I have a 960 but looks like a s90 with the same headlites etc as a S90 and the car only takes spare parts meant for a s90.
Well i have been having some problems with my fuel line recently and just managed to get it fixed by changing the fuel pump.
1. I have this very annoying sound whenever i step hard on the brakes or corner a bit too fast, the sound is of the underbody of the car grinding against the tires; i have checked all the bushings and discovered that they are all fine so what do i do?
2. i have a slight misfire as if my plugs failed or something when i try driving the car but it stops doing that once i acclelrate more then 2000 rpm. I have checked my plugs and the plug wires to no avail.
I would really appreciate an answer to the above questions.
Thanks
Old Dec 15, 2008 | 07:27 AM
Default RE: Problems with my 960/s90
1. Front or rear?
2. Are the coils cracked?
Old Dec 15, 2008 | 10:17 AM
oseyio's Avatar
Both the front and rear ends
Old Dec 15, 2008 | 12:49 PM
Check all the bolts for the front suspension parts. Also the 4 bolts holding the engine cross member to the body.
Old Dec 17, 2008 | 06:08 AM
oseyio's Avatar
hi,
i have checked the bolts of the crossmember and of my front suspension in short and it all seems ok.
pls what do i try next?
Old Dec 17, 2008 | 07:47 AM
Have you inspected the control arm bushings really good?
Old Dec 18, 2008 | 09:46 AM
oseyio's Avatar
i had a look and they seemed ok!
Am really at a loss!
but 1 thing i've noticed is that the back is considerabely lower than the front! does this affect in anyway the ride or suspension?
Old Dec 18, 2008 | 03:57 PM
Rear shocks might be bad and causing one of the noises.
jpirish
Sep 14, 2023 06:33 AM
larry150
Nov 28, 2007 09:06 PM
Squid56
Aug 25, 2007 11:57 AM
Squid56
Sep 12, 2006 01:27 AM
1998S90
May 8, 2006 09:03 PM
