S90/960 front suspension
Old Jul 31, 2007 | 12:54 PM
larry150's Avatar
Default S90/960 front suspension
I have a 97 S90 110k miles. The front end seems loose and makes rattle noise drivers side. The shop says it needs new struts,ball joints, control arm etc....$$$. The estimate was $2200. Tough to put that into a car worth maybe $3800. I think I'll try to do some work myself. Any suggestions on what to start replacing first.? thanks
Old Jul 31, 2007 | 03:05 PM
Johnny Mullet's Avatar
Default RE: S90/960 front suspension
Take it to another shop and get another opinion. The rattle noise could be just a link pin, but if the car feels loose, then there is probably more. Start with the ball joint and control arm bushings first. Save the struts for last unless it's real bouncy or they leak.
Old Jul 31, 2007 | 03:41 PM
larry150's Avatar
thanks Johnny
Old Jul 31, 2007 | 05:00 PM
larry150's Avatar
Okay after about five min. my wife andI narrowed down the source of the noise to a leaking strut.Is this a do it yourself repair or a pullout the check book job?
Old Jul 31, 2007 | 09:04 PM
Depends have you ever changed them before on a car?
Old Jul 31, 2007 | 10:02 PM
larry150's Avatar
Changed the shocks on my F150. Not too bad. Although I didn't have to compress any coil springs. How much shouldI expect to pay for a strut change. I fiigure parts to be around $200 per side up front.
Thanks for the Input
Old Jul 31, 2007 | 10:13 PM
Depends on shop may be between 1 to 2 hours.
Old Nov 28, 2007 | 09:06 PM
shelbylay's Avatar
I had that same problem with my car. There is some sort of rubber ring/washer somewhere im not sure where. but it wears out and is metal on metal knocking together. thats what they guys at coastal automotive told me here in st augustine fl
andys90
Apr 12, 2012 04:44 PM
andys90
Suspension
Apr 12, 2012 06:30 AM
960 rookie
Oct 22, 2008 07:50 AM
Squid56
Aug 25, 2007 11:57 AM
1998S90
May 8, 2006 09:03 PM
