Sensus S90 2018
Old Apr 27, 2022 | 02:53 PM
Boris84's Avatar
Default Sensus S90 2018
Hello, i took my first Volvo S90 momentum D3 2018 few days ago. And i have problem, i have only 1 usb port so Apple Car play is not working, my navigation also do not work. Car is using internet via blutoot and maximum i get this online map, and spotify. How can i update my Sensus so i can get Car play.? Any suggestions please?
Old Jun 14, 2022 | 10:48 AM
Cruiser's Avatar
To update you need to connect the car to the internet, best way is if it can pick up your home wifi, you'll see the settings in Settings - Communication, you could however be ticked in the actual car modem settings with an expired subscription, this might be blocking out the normal function of the unit so you need to check that whole section for what's enabled and what isn't, you will need to enter your home wifi password and username if you want to try that route, once connected the car will say if there are updates.
TrafficPL
Apr 12, 2022 01:22 PM
CamStat760
Jun 20, 2021 08:53 AM
Terence77
Aug 30, 2019 04:14 PM
kai23
Feb 23, 2018 11:59 PM
