Diagnostic Tool for V40 -1998-2005?
Old Dec 17, 2024 | 02:48 PM
Hi!'s Avatar
Hi!
Question Diagnostic Tool for V40 -1998-2005?
Today I performed brake bleeding on my beloved V40-2.0 from 2003. But... then the ABS is NOT bled, right?
I did not find the forum-info I am looking for. Maybe I am using the wrong English search terms?? I am looking for a diagnostic tool for an old style V40 phase III in order to perform bleeding on the ABS. I read that there's VIDA and the VICE unit. But as far as I can see Dice is strictly diagnostic and cannot perform an ABS bleed operation. Which tool do/did/would you use?
Another question that came up to me is this; Why not just flush the ABS, catch the dot4 fluid at every wheel and skip the standard vacuum brake bleeding operations? If I recall correct Haynes says to first perform an ordinary brake bleed and then the ABS. Why a standard vacuum bleed if you bleed all lines anyway in an ABS bleed?? Thanks a lot for your answer!
Old Jan 26, 2026 | 04:08 PM
sallyromme12's Avatar
I use a Top Don ArtiLink 500 on my old V70, paid £40 for it, it's been great to give me codes to mechanic over the phone, asking him "do I need to walk to the shops now?". It also clears messages and codes and live data but it's a bit tricky to navigate through as it's a small screen and uses arrow keys to move through menus.
snaptube vidmate
ChristianWestDK
Mar 18, 2024 06:07 AM
dougrock
Jan 11, 2023 03:08 PM
mt6127
Feb 4, 2015 10:32 PM
Joe Flies
Mar 30, 2011 07:40 PM
Volvo_User
Oct 25, 2003 02:58 AM
