Engine sensor fuse blowing
Old Jun 20, 2016 | 03:34 PM
Honmusam's Avatar
Default Engine sensor fuse blowing
I am having a problem with my engine sensor fuse. Is keeps blowing? The car will start but will not idle. It will run if the pedal is depressed but as soon as it is released the car dies? I'm thinking one sensor is shorting but can't find Info on how to test the different sensors? Where would be a good place to start my search for a faulty sensor? Any info would help.
Old Jun 20, 2016 | 09:13 PM
check out volvowiringdiagrams.com - you should be able to map from the fuse to the components on that circuit.
thekid
Jul 10, 2020 07:55 PM
kcpaz
Apr 11, 2009 01:18 PM
tbenner
Feb 20, 2008 11:09 AM
macdogd
Dec 25, 2007 09:27 PM
mrchuck85
Feb 28, 2007 09:08 PM
