Oil pressure light on at idle when cold
Old Dec 2, 2019 | 12:38 PM
Patrickane's Avatar
Default Oil pressure light on at idle when cold
Hey guys. I got another issue with my car... the oil light comes on when it’s cold and the first couple minutes of when it gets to operating temp. If I hold it at 1,200rpm or more it turns off, I’ve ran 5w-30 and 10w-40, the 10w-40 seems to be better than the 5w oil. Any suggestions?
Old Dec 4, 2019 | 02:32 PM
you probably need to drop the oil pan and check if there's any sludge in the pick up and consider a refresh on the oil pump o-rings. As a quick fix you can try doing a Seafoam treatment and refill with full synthetic but my concern is you are risking permanent damage without servicing the pump.
Old Dec 4, 2019 | 03:57 PM
Patrickane's Avatar
Ok thank you, I’ll drop the pan this weekend
pablogiovani
Engine & Internal
Dec 10, 2012 08:29 AM
rpj
Aug 23, 2011 09:12 AM
gyrene66
Mar 6, 2011 04:30 PM
sdam87
Nov 22, 2010 10:13 AM
neonracer193
Feb 18, 2009 09:37 AM
