sloppy gear box
Old Jan 30, 2008 | 09:32 AM
borgpicard's Avatar
Default sloppy gear box
can anyone tell me, whats going on, i have to put gear into 2nd to get it into 1st sometimes ?
Old Feb 10, 2008 | 12:28 PM
dragonslair's Avatar
Default RE: sloppy gear box
A common problem amongst Volvos of the older type. It is usually the reverse gear that normally causes the problem. Try looking for worn bushes, (usually nylon and rubber) under the selector box from beneath the car. If you do hard gear changes they wear out very quickly. Normal gear changes, they may last up to 2 years. Also dependant on environment the car is subjected to. ie. Lots of road salt plays havoc with the aluminum bolt that runs through the selector.
Bushes are main deler parts only. Theyll cost around £14.00.
Old Feb 10, 2008 | 02:32 PM
borgpicard's Avatar
thank you i`ll give that a try
joesid
Nov 22, 2008 04:42 PM
daver80
Sep 20, 2007 11:46 PM
possumgrape
Nov 6, 2005 06:06 PM
Bin
Oct 27, 2005 09:12 PM
Fedup
May 8, 2004 06:37 PM
