Timing belt question
Lot of different opinions to answer your water pump question. I've a 98 xc awd with 200k and intended to replace it with the timing belt. The dealer had the time and stood to profit from it. I made it clear that if I had major failure $$$ I wasn't putting the bucks back into the car. The dealer/techs were adamant that they didn't see water pump failures. So it would seem to be a pretty objective opinion where dealer had nothing to gain with their answer, and something to gain if they replaced it. So I opted not to replace with timing belt this time. Next time I do plan on doing it, as 270k miles would seem a point where you could assume just about anything on the car has had a long life already. And if the car is still running well, I wouldn't want to kill it with failure to replace that. I do think the dealer was taking into consideration their experience with 98's as they work on a lot of them. Your year and model is different and maybe I would have got a different answer. Good luck!
If you are having the work done, I say yes. If doing the work yourself, I would not, unless it's leaking. Don't hear of to many water pump failures that destroyed the motor. A water pump usually leaks before it fails. If you are doing it yourself, it's no big deal to replace the pump if it starts leaking in 2 years or 20,000 miles. However, if you are paying someone to do the belt, you save a lot of $$$ IF you have a pump leak or fail.
