v40 cam seal leaking
Old Dec 20, 2018 | 07:55 PM
nipplemilk909's Avatar
Default v40 cam seal leaking
hello im in need of some help on my volo
Cam gear seals
time belt
crank seal
ive taken apart and done this job just about three times already with the same problem of excessive oil leaking.
could the oring inside the gear be causing this ?
looks like the giant leak is coming from the vvt exhaust gear
ive gone to many junk yard v40s to look at the seals and i got the right one, how do i replace it ? the last three times ive put the seal on the boarder of the block ....
should i put the seal on the gear first then install????
and one more question about the vvt gear, everytime ive taken off the gear i dont see what the people on the youtube videos are talking about but the gear doesnt really have play to mark twice so ive just put the gear on the mmark torqued it , then put the belt on,..... is this wrong ???
Old Dec 21, 2018 | 09:34 PM
The VVT gear is driven by oil pressure so its likely the cause of the leak, not the cam seal. It will likely require replacement but you can search for other posts to see some discussions on rebuilding.
Livens
May 4, 2020 07:19 AM
tr_car_nut
Jan 15, 2017 09:33 AM
nasko00v40
Apr 13, 2013 03:48 PM
nasko00v40
Engine & Internal
Mar 19, 2013 06:04 PM
nasko00v40
Mar 19, 2013 06:03 PM
