2006 V50 T5 AWD misfire at high altitude
Old Mar 3, 2016 | 11:43 PM
Jephrobrewer's Avatar
Default 2006 V50 T5 AWD misfire at high altitude
So I know I need to replace the PCV but I am getting misfires in Colorado only when I'm topping mountain passes above 8000' or so.
I'm getting mix too lean code and O2 sensor code. Any suggestions?
--jephro
Old Mar 4, 2016 | 07:23 AM
to the forum Jephro
Hopefully someone will be along with some ideas.
Old Mar 5, 2016 | 07:18 PM
How many miles? start with the simple - look for vacuum leaks/ intake leaks. its possible the MAP (altimeter) sensor is at issue or the O2 sensor but I'd look for a small vacuum leak first. You may want to have a shop do a smoke test before replacing parts if you don't find something obvious.
Bonsaidan
Oct 19, 2013 10:41 AM
Bonsaidan
Jul 17, 2013 08:11 PM
Domm
Feb 14, 2009 11:09 AM
s70buff
Jan 26, 2009 06:48 PM
