2012 V50 1.6 drive cooling fan/over heating
Old May 28, 2016 | 03:54 AM
jimbo66's Avatar
Default 2012 V50 1.6 drive cooling fan/over heating
Hello, have an issue where my V50 started to overheat, temp gauge rose above centre and a whiff of steam from header/expansion tank. I immediately turned on cabin heater which lowered engine/coolant temp.
Car occasionally overheats, steam from, now split, expansion/header tank and cooling fan does not appear to operate, temp gauge no longer goes above half way for some reason. The fan spins freely so is not seized, and I have also replaced thermostat and temp sensor. Running car with heater on permanent so as summer (??) approaches can get quite warm.
Thankyou.
Old May 30, 2016 | 08:02 PM
Does the fan engage? if your car was overheated the fan should run for a few minutes after the car was shut off. If not you may need to check the relay, connectors and even bypass the relay to see if the fan motor will spin the fan.
Old May 31, 2016 | 04:12 AM
jimbo66's Avatar
Default V50 Overheating
Thanks, the fan spins freely by hand but does not operate at all by itself, either when the AC is on ( should run at low speed ) or when the coolant temperature sensor is unplugged ( told this triggers over heat detection and forces fan to operate at full speed ). There is no relay, that I am aware off, the controller unit on the fan does all the clever stuff. Consensus is the fan needs replacing, with after market a fraction of the Volvo price ( here in UK ) or I go for a secondhand unit !
CarpeNoctem
Aug 19, 2009 06:51 PM
yoff14856
Jan 6, 2009 04:51 PM
elouadj
Jun 25, 2008 07:00 PM
dadto5
May 24, 2008 01:46 AM
DaveNY
Nov 27, 2006 08:02 PM
