anti skid service with fault codes
Old Sep 28, 2014 | 10:53 AM
reckyb's Avatar
Default anti skid service with fault codes
So i was driving home, first time in the rain.
I wasn't going fast, car was warm . .had driven 1 km in rain. ..
You go along the road there is a bout a 120 degree left hand turn up a moderate hill with a speed bump. I had lights and a/c on as i went over the bump i noticed the car would still pull with the throttle not pushed i checked this a few times by pushing on the throttle and same thing . .revs would drop to 1500 then go up to 2000. .the throttle became unresponsive and a few hundred meters later the warning came on.
The codes . .
p1602 - throttle unit internal fault
p2135 - throttle/pedal position sensor/switch a/b voltage correlation
p2125 - throttle/pedal position sensor/switch e circuit
p2015 - intake manf runner position sensor/switch circuit range/performance bank 1
I cleared the codes restarted the car a few minutes later and it was fine. Went for a drive on wet grass trying to provoke spin and seemed to work fine.
Do these codes seem to be of things that can fail, because if they can i need to make a plan.
Any comments welcome.
giannis-21
Aug 10, 2011 01:50 PM
pologurl81
Feb 28, 2009 08:14 PM
erikman
Dec 13, 2008 09:00 AM
akirk6884
Jan 16, 2007 12:23 AM
