cabin air filter
Old 09-12-2010 | 08:17 PM
a4ty4d's Avatar
Default cabin air filter
Does anyone have any experience with the cabin, or pollen air filter. I have never done this in my v50 and am looking for tips to lessen my learning curve.
Thanks, John 2007 v50, 1998 v70, 1991 245SE,
Old 09-12-2010 | 08:27 PM
They are a pain to do. The access panel is next to the gas pedal. I remove the gas pedal then the mounting plate for the pedal. It makes it easier to get in there. I do not think you could work the filter out otherwise.
Old 09-14-2010 | 10:39 PM
AutoNaut's Avatar
This is the first car that I have made good use of my universals for my ratchet wrenches. You will need one either for 1/4" drive or 3/8" to get the gas pedal off. I heard one mechanic recommend a cordless mini impact driver.
I just did mine last month and about half way through I was asking myself, why? I got it done though.
By the way, while doing the job I found the climate control cabin temp sensor all clogged with dust. It has a little motor with a fan to draw air across the sensor. You can see the little vent for it just behind the radio console. I removed it and cleaned it out with a little compressed air.
Stan
Old 09-15-2010 | 07:31 PM
a4ty4d's Avatar
What is the worst part of the job? Is it hard or just a hassle?
Old 09-15-2010 | 08:27 PM
Getting all the screws out is the worse for me.
Old 09-16-2010 | 11:28 PM
AutoNaut's Avatar
The nuts that hold the gas pedal in place. I want to try a mini impact driver next time or something powered.
BTW, this might be helpful: http://forums.swedespeed.com/showthr...filter-writeup
Stan
Old 09-26-2010 | 10:04 PM
a4ty4d's Avatar
Default No biggie
This weekend I changed the cabin air filter. It is something I am glad I don't have to do as frequently as an oil change, but it wasn't all that bad. I must say that thanks to your good advice I was well informed and prepared for what to expect. I know if I was doing this cold my head would have exploded. I had more trouble with taking the plastic shrouding off the dash than anything else. I did find that whoever did it before me (it was a Volvo filter so it must have been the dealer) did not put the top screw back on the filter housing so there were only 2 screws, also they had put the filter in upside dow and backwards (arrows facing toward engine compartment). I did not have a cabin temp sensor in my 2007, at least where I expected to see it, behind the radio panel. Anyway its done, no biggie, but then I was prepared.
Thanks for the help.
John
Old 09-27-2010 | 08:37 PM
Glad you got it done.
debargha
02-24-2015 10:46 PM
nigel_miguel
01-07-2012 05:09 PM
bluemagicbus
05-17-2011 07:18 AM
edahlgren
10-21-2010 06:24 PM
Ahmed
03-28-2008 04:22 PM
Quick Reply: cabin air filter
