Check engine light on, red triangle saying "try to slow down or shift up"
Old 04-17-2019, 09:55 AM
Ds3991's Avatar
Default Check engine light on, red triangle saying "try to slow down or shift up"
Hi!
So my check engine light comes on and i get this message reading " try to slow down or shift up" on my dashboard. Idling while driving and really idling when at a stop. Going uphill it gets lretty damn rough as well. So i got a code reading ( p0300 , 0203, p0303) changed the coil pack on cylinder 3, still not driving right,, spark plugs look fine. What the hell is gong on?????? Please help!!!!!!!!
Old 04-17-2019, 10:35 AM
0300 is a generic misfire, 0203 says your #3 injector is malfunctioning, 0303 says you have a misfire on #3. Time to pop out injector #3 and test it out... Recall that misfires can be caused by fuel or spark - so this looks like a fuel delivery issue.
Old 04-17-2019, 03:39 PM
Ds3991's Avatar
Like a fuel injector?
Old 04-18-2019, 12:30 PM
yes. the fuel injector. You should be able to find a local shop that will test/clean or buy a replacement. It does have a solenoid switch so it can either fail by clogging with debris or the solenoid can fail and won't pulse properly.
mikey4040
02-28-2021 04:34 PM
Scott W
01-18-2019 09:30 AM
SwedishFury
09-11-2015 10:53 AM
henrysin44
03-25-2015 09:00 AM
NJFordBoy
10-10-2009 03:09 PM
Quick Reply: Check engine light on, red triangle saying "try to slow down or shift up"
