Drivers side engine mount replacement - please help!
Old Apr 4, 2022 | 06:06 PM
LynsT5's Avatar
Default Drivers side engine mount replacement - please help!
Hi all,
I recently bought a 2005 V50 2.5L Turbo. I just replaced the right hand side engine mount, which has helped with the brutal vibrations I was getting, but sadly it has not solved it completely.
I've found the lower torque/transmission mount (which seems in good shape visually) but from what I've read, maybe I need to remove it to properly check it?
I just found the drivers side (left) engine mount under the battery box, going to use a floor jack with wood to support the engine like I did for the right hand side. Any other suggestions or tips would be great!
Finally I just want to confirm there are only 3 engine mounts in the 2005 V50?
I usually get all my tips from You Tube, but I can't find a video for the drivers side engine mount for the V50.
Any advice would be greatly appreciated ; ) Thanks everyone!
Old Apr 6, 2022 | 06:41 AM
Dingus1's Avatar
It does look like 3 total engine mounts (I did a google search) and I would remove the transmission mount to inspect it as well. If it's all floppy like an old man with ED, its time for replacement.
Thildy
Sep 17, 2021 07:42 AM
dorvin
Dec 27, 2015 12:44 AM
ThomasK
Dec 7, 2015 02:51 PM
geraldc70
2001-2013 model year V70
Apr 5, 2014 11:43 AM
wrldky
Jun 3, 2013 07:45 AM
