help finding a solution to whistling
Old Sep 18, 2013 | 08:59 PM
k8d's Avatar
k8d
Default help finding a solution to whistling
Wondering if anyone can help. I have a 2005 V50 with 61K. At the end of last week it started making a whistling sound when I removed my foot from the accelerator. It went in for service yesterday (with a mechanic that I COMPLETELY trust! He has never let me or anyone in my family down in the 20+ years we have been bringing cars to him):
1. when I described what was happening he immediately said “sounds like a vacuum leak”
2. when he ran the code it came up as mixture issue between oxygen/gas mixture
3. He ran the smoke test to make sure, the test came up with no leaks.
4. He checked the exhaust system when the car was on the lift. All clear.
5. He checked the alternator, all the spark plugs, and intake manifold. All clear.
6. After a test drive he did another smoke test thinking that the car needed to run, same results no leaks.
7. No problems during idle, no stalls or high revs.
8. After a bit of a delay between turning of key and turnover of engine at cold start. But then quickly comes down to normal idle
Here are the symptoms:
1. as soon as I remove my foot from the accelerator the whistling starts.
2. The whistling sound is somewhere on the drivers side.
3. there is a slight vibration on the driver’s side when car is stopped. I can feel it through the seat.
4. when over 55 mph and I release my foot from the accelerator, no whistling.
5. Good 5 secs. of whistling after turning car off.
Anyone have any clues?!?! Ever hear of this happening??? I really do not want to take it to the dealer and pay dealer prices, but I think this is my only option.
Old Sep 19, 2013 | 07:19 AM
ES6T's Avatar
Does it go away if you remove the oil cap or dipstick?
Old Nov 23, 2013 | 11:52 PM
AutoNaut's Avatar
It is likely the PV Breather. These are known to be an issue with these cars.
PCV Breather System Kit for P1 C30 C70 S40 V50 Models
Stan
Old Jul 14, 2014 | 02:01 PM
TheRedX's Avatar
I had the exact same problem!!!
The best way to see if it is your Engine oil trap is while the whine is happening, remove your oil dipstick (put a rag between you and the dipstick) if it is the Engine oil trap, you will hear an out-gassing and the whine will go away... when you put the dipstick back in, the noise will return.
damy223
Aug 26, 2010 07:07 AM
Svtfiveoh
Apr 15, 2008 06:51 PM
clash0901
Aug 9, 2007 04:36 AM
tennisguy
May 18, 2006 07:32 PM
natace1972
Dec 23, 2005 05:56 AM
