How to disable Low beam failure light - LED upgrade
Old Mar 31, 2016 | 05:02 PM
Atelaroli's Avatar
Default How to disable Low beam failure light - LED upgrade
Hello!
I recently upgraded my low beam headlights to LED's on my 2005 Volvo V50 T5. I did a lot of research beforehand and made sure to have my DRL's disabled before installing the kit. I also ordered a disabler that is supposed to prevent the low beam failure light from coming on. The kit was super easy to install (took less than 4 minutes) and the lights look and work great! But after a few minutes of driving the low beam failure light flashes on and off once a minute or so on my dashboard. The headlights don't flicker or anything, but the little orange light flashing on intermittently is super annoying. After looking through countless threads I have been unable to find a fix. I did see one thread talking about running a relay to the battery for HID's due to a wattage issue. But the LED's use LESS wattage than the factory halogens so the power doesn't seem to be the issue here. Anybody else come across this issue? Any help would be much appreciated!
Old Feb 16, 2018 | 07:59 PM
Marcus66's Avatar
I am also having this issue with my 2016 XC60. That almost non-stop flashing on the dashboard is driving me nuts and is becoming very distractive. Did you ever find a solution to this problem?
Old Apr 4, 2018 | 07:17 AM
Deus89's Avatar
Default Same Problem
hello!
i replaced my H11 lightbulbs by LED’s yesterday too.
also the flickering warning sign when driving.
anyone ever found a solution to this?
thanks!
Old Apr 4, 2018 | 04:18 PM
tony1963's Avatar
The system senses a certain amount of resistance and amp draw. When switching to LED bulbs, this changes the resistance and amp draw. Thus, the warning.
Old Apr 4, 2018 | 05:27 PM
Deus89's Avatar
That’s what i’ve been thinking.
i guess i’ll have to live with it then? Or is there a known ‘fix’ to it?
Old Apr 5, 2018 | 01:09 PM
tony1963's Avatar
Go back to standard bulbs. Problem solved.
Old Apr 5, 2018 | 03:53 PM
Deus89's Avatar
that’s what i was afraid of
well, we shall see how annoying it becomes. Thank you very much, anyway!
Old Apr 19, 2018 | 10:31 AM
osteovolvo's Avatar
my 2005 v60 2.5t AWD has the low beam failure dash light
yet all the lights work perfectly and have for months.
What gives? I have the 55 watt bulbs so no resistance problem.
Can an OBD2 scanner clear it?
I even disconnected the battery and it returned.
High and low beams work perfectly so I can't imagine a ballast problem or melted wires.
thanks
Old Apr 23, 2018 | 06:58 AM
javiabt's Avatar
Default Finding a solution too
Hi! I put Low beam LED light bulbs in my XC90 a month ago. I had to install a pair of resistors in order to avoid the "warning" problem and it dissappeared.
Anyway, the beam pattern was not perfect (some light escaped upwards) and although nobody complained about it when driving, I was not satisfied with it, so I bought new H7 LED bulbs, and with these, the "cut" in the pattern is perfect. It is like the one you have with the halogen bulbs but with much better light.
The problem now is again the "fused bulb" warning. With these new bulbs the resistors don't seem to work. Everything is connected exactly the same way, but in some minutes after I start driving, the warning appears again. It is really annoying. I have checked all connections.
I think that if you connect a 50W resistor, it should not give you the warning even if you don't put the bulb, because it makes the system feel that it is connected. That is why I do not understand why I have the problem with these bulbs.
I will go on trying different possibilities and tell you my conclusions, and please do the same. LED bulbs are a great improvement for our cars.
Old Apr 24, 2018 | 12:20 PM
osteovolvo's Avatar
I've figured out that the passenger low beam comes on with the parking light,errantly.
If I'm in DRL or full running lights both the parking bulbs and low beams are on. I can deal with that.
So to get rid of the "low beam failure" warning dash light, every time I start the car I hit the reset button on the directional shaft
and turn the ring to "miles til empty" or "mpg" or just a blank screen and it never comes returns!
Someone wired the parking light to the passenger low beam. Don't know why.
Thanks for your help.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
jasonthaynes
Dec 2, 2012 05:32 PM
izeus9
Oct 25, 2010 03:00 PM
llcoollam
Apr 24, 2006 06:54 PM
V50T5
Mar 19, 2006 04:35 PM
