Identifying BAD Wheel Hub bearings
Hey all,
I have been searching all over this site and finally figured that the SCREECHING/GRINDING/SQUEALING sound that I am getting from my 2006 V50 2.4 is a bad wheel hub bearing. The sound is intermittent but extremely loud. Brakes are fine, not a scratch on the rotors and the pads are still in decent shape.
How do I figure out which wheel is causing the issue? At $315 each assembly here at the "stealer" in Calgary, I don't want to go replacing them for nothing.
Also, it sounds like it is a relatively simple job for a DIY with some tools and skills.
Any help would be GREAT.
Thanks.
Brian
Thanks.
Brian
Thanks Tech.
I jacked up each wheel and gave it a spin. The rears have a very minor rub (with the rear bias on these cars, not surprising that I will be changing the rears soon anyhow). Then I found the culprit wheel. The front passenger wheel was brutally loud. Removed the wheel, took a look at the brake pads, pads are fine, not a scratch on the front of the rotor. Tried to look at the back side of the rotor and that's where I noticed it, a rock was stuck between the rotor and the strut. Removed the rock and no more noise. Much cheaper than hub assemblies.
Thanks for the tip.
Thanks for the tip.
puxnstx
Dec 13, 2014 11:36 AM
