oil plug washer
Personally I believe the aluminum oil plug washer seals better then copper, but they both do a good job. You should always replace the washer after each oil change. I have seen many times where the washer was left off creating a small drip. Owner does not see the oil hitting the ground because the engine cover catches it.
