PO 2187 thrown today
Old Jan 18, 2016 | 12:54 PM
urdrwho's Avatar
Default PO 2187 thrown today
It is cold with a 18F temp and wind chill of 5F.
Went shopping with my wife and I noticed that the car was running a bit odd - rough at first. After about the third store, started the car, exited parking space and saw a CEL. Car wasn't showing any signs of rough running or anything that might worry me so we made two more stops and headed home.
Scan tool shows a PO 2187. I cleared the code and it didn't come back.
I haven't checked to see if the gas cap or oil cap are tight. If it is a PCV issue, I won't do the job, too cold and from what I read it is not a cheap job. As I have said on other occasions I am not a fan of the engineering on some Volvo PCV systems. To me it is over engineered. If 99% of the cars can run with the little valve going into the valve cover why did Volvo feel the need to create a nightmarish system of hoses and traps.
Oh well enough of complaining.
Is there anything else to look for?
Old Jan 20, 2016 | 08:52 PM
code is saying you are lean at idle. could be a dirty MAF, temp sensor or air leak in the intake tubing/boots. Good thing is, your car won't feel the wind chill, just the temperature... :-)
Old Jan 21, 2016 | 06:21 AM
urdrwho's Avatar
Yes it is a lean situation but I'm trying to find the #1 culprit and if not that.....start down the list. The car has been driven for about 100 miles and no codes but cars don't heal them self. Or was it a situation of the quality of gas and the cold?
Very cold outside so I wasn't into doing an in depth check but I checked the bigger stuff like intake air tubes, tubes to turbo and they seemed nice and tight.
Time will tell or should I say my wife will surely tell me if the CEL illuminates.
Old Jan 22, 2016 | 08:36 AM
quality of gas is not a likely cause - cold can make parts stiff so its plausible that could expose an air leak. 18F is not overly cold to a car - particularly if you are running the proper weight oil (I assume you are running full synthetic - so even a 5-30 is good down below 0F). I'd just check the gas cap and keep an eye open for any new codes and see if anything else is stored.
Old Jan 25, 2016 | 06:51 PM
urdrwho's Avatar
The car has gone for hundreds of commuting miles and no codes.
thphon
Jan 27, 2016 10:55 PM
bigsparky
Feb 19, 2015 06:36 AM
CheapCharlie
Mar 6, 2014 11:58 PM
shai_kino
Feb 28, 2011 07:11 PM
maxt
Dec 18, 2004 12:15 PM
