Replacing linear solenoids (shift solenoids)
Old Sep 28, 2018 | 02:56 PM
habbyguy's Avatar
Default Replacing linear solenoids (shift solenoids)
Hi, all...
Here's a link to a short (11 minute) video I did detailing the replacement of the three linear solenoids in my 2005 V50 (same as an S40, C30 or C70). Really not a difficult job... I spent a good bit of time getting the top center bolt out of the valve body cover, but I know I could have pulled the radiator hose that was in the way and made it a lot easier - just didn't want to drain my cooling system. ;-) The three solenoids cost about $71 for a set of the three Rostra linear solenoids (actually a bit less with an eBay discount I had), and the whole job, including test "training" drive probably took a couple hours at a leisurely pace, and (of course) included a transmission fluid change (forth one in the last 500 miles, which has my fluid looking nearly new). Thanks to Tony for some good advice on diagnosing the shifting issue I was having, and for the tip about using four quarts to refill a drained tranny (rather than trying to measure the fluid level with Volvo's thoroughly inaccessible dipstick).
2005 Volvo V50 Shift Solenoid Replacement Video
Old Sep 30, 2018 | 09:12 AM
tony1963's Avatar
I appreciate the feedback.
It is much easier to lower the subframe and hold the engine up so that you can reach the transmission pan. For the life of me I don't know how you did it with the cooling system in place.
To all of those who have paid for a transmission replacement in the past, I tried to tell you that this will fix it. But, what do I know?
Old Sep 30, 2018 | 06:34 PM
habbyguy's Avatar
Tony, it was pretty fiddly getting that top center bolt out, but I figure in the end it was quicker than draining the cooling system and running to the auto store to get more coolant. I used an articulated 3/8" drive that let me work around the hose (or really, the hard plastic piece in the middle of a hose - why did Volvo do it that way???).
I couldn't agree more about most transmissions being repairable. Normally, as long as you don't have obvious slipping while IN gear, the problem is a "control problem" which is solenoids, valve bodies or both, often due to poor maintenance (read "dirty fluid").
FWIW, the tranny is shifting like a new one, and I was happily surprised to see that the manual shifting has much improved as well. It's not "Ferrari quick" or anything, but is certainly smooth and solid.
Next trick will be the LCAs, struts, strut mounts and axles. Probably won't need to make a video of that - I would guess there are already plenty.
Old Oct 6, 2018 | 06:28 AM
tony1963's Avatar
We used to have some nay-sayers here, some of which were banned for being idiots. I tried to explain the process but the former Mr. Elmer Idiot explained to everyone that I didn't know what I was talking about and said that the entire transmission needed replaced.
After several thousand Volvos, what do I know, right?
Old Oct 6, 2018 | 08:06 AM
ES6T's Avatar
Apparently not the difference between a P2 and a P1.
I don't know who you argued with about replacing solenoids vs. the transmission, but the reason some shops might recommend the transmission is to be 100% sure of a fix.
I can price solenoids or a valve body, but I warn the customer (especially with high miles) that if I do this and there are still problems, it will need a trans. Some opt to try it. Some opt to leave it alone until it gets worse.
Obviously if you are doing it yourself, labor is free so it's definitely worth replacing the solenoid first.
Old Oct 6, 2018 | 12:25 PM
tony1963's Avatar
All of my work on transmission solenoids has been with the P2 chassis. To date, after a couple of dozen solenoid changes, we have yet to have one that didn't fix the problem. Admittedly, I wouldn't put solenoids in one that had a transmission that either wouldn't go into gear properly or slipped.
We have fixed all of the abrupt shifts by doing the solenoids. Highest mileage unit fixed was right at 180k miles.
The former Mr. Elmer Idiot is no longer in the forum. He was either tossed out on his gazoo or left voluntarily.
Old Oct 6, 2018 | 01:11 PM
habbyguy's Avatar
FWIW, I retrieved some service history from the local Volvo dealer (they cut off the customer info). They were willing to do this for me, since I'd been a previous (mainly parts) customer.
I see where the PO had my V50 in for service, and got a $10k estimate for what the car needed. That included struts (did those) LCAs (ditto), gearshift gate (also did that) and axles (them too). The kicker was the $6700 for the transmission replacement (that's before labor). Of course, I spent about $650 all-up on all of those fixes ($0 for labor, of course), and the car drives, handles and shifts like a new one.
IMHO and experience, I've never seen a transmission with a "control problem" (bad / clunky shifting / flares, etc.) that didn't have a true "slip" (when in gear) that wasn't fixable with some combination of shift solenoids, new fluid, pressure switches (Hondas), etc. I'm sure there ARE some out there that need to be replaced, but holy moly, Batman... I can't imagine anyone ever dropping well over $7k into a 13 year old Volvo. OTOH, that makes a Volvo with a transmission problem a smokin' good deal for those of us who don't mind bathing in tranny fluid. ;-)
Old Oct 6, 2018 | 03:03 PM
tony1963's Avatar
Going to the dealer with an older car is not cost effective and often the only thing that the person wants is a diagnosis. The dealer does basic service work and adjustments on newer vehicles.
It is akin to hiring a lawyer to write up a shopping list.
Old Jul 27, 2022 | 01:33 PM
intisar's Avatar
Thanks for the excellent and detailed video. I have a 2005 Volvo v50 with 185k miles that I purchased about 6 months ago. The car had hard shifting mostly in low gears. Changed the transmission oil and it got better, but sill have hard shifting once I drive for about half an hour or so. Especially when coming to a stop. No gear slip though. After reading this thread, I believe changing solenoids are in order. I would appreciate, if someone can guide me as to where to get the solenoids from? part number?
Old Jul 27, 2022 | 03:07 PM
If you have the 5 speed automatic, its an Aisin AW55-50 and google is your friend. :-)
something like this?
Amazon Amazon
Old Jul 28, 2022 | 12:02 PM
habbyguy's Avatar
The kit I got was from Rostra (a very legit supplier of transmission parts). It contained only the three linear (larger) solenoids, which did fix all my problems. IIRC, it was around $100.
It's also better if you can do a reset of the "fluid counter" (to tell the transmission that you've changed the fluid) and reset the adaptations when you swap the solenoids. These will both help the transmission adjust itself to the new configuration, and will result in perfect shifting quicker than just letting the transmission relearn on its own.
Old Jul 28, 2022 | 12:40 PM
intisar's Avatar
Great!.. thank you mt6127 and habbyguy.
In the middle of replacing the blower motor (what a pain) .. once done, will work on solenoids. I 'll definitely go with Rostra.
Do you mean that I need to use some software to reset the fluid counter? Like Veda? If so , can you please provide the link to download Veda.
Thanks
Old Jul 28, 2022 | 01:22 PM
There is no fluid counter in the automatic transmission. On the 4/5 speed autos, drain/fill just means you refill the same amount you drained out then use the dipstick to check the fluid level. The suggestion was that when you fully drain the pan you will need to add about 4 quarts to refill, but you then use the dipstick to check and top off since you never know if the level was correct to begin with. Note on the dipstick there's a cold and warm fill line. The process I've used is to drain, measure what you drained, fill with the same amount, run the engine to pump the new fluid around (no need to drive around the block), repeat (drain, measure, refill, check level to the cold line. With each drain cycle you should wipe the dipstick on a white cloth or paper towel or run some of the drain flow through a paper towel to check color. It should go from brownish to reddish brown to mostly red with each cycle. 3 cycles should be enough to use a 12 quart case. Once that is done, check the dip stick and fill to the cold mark. Then you need to do a 10-15 minute driving cycle to warm up the transmission (I assume you don't have VIDA or a tool that can report when the transmission reaches 55C), so just do a mix of stop/start and variable speeds to go through all the gears to unsure the transmission reaches a normal operating temp. Then you can use the dipstick and check the level for the "warm" mark. Check YouTube for vids on the process and google for a recommended driving cycle for transmission level checks.
Old Jul 28, 2022 | 09:12 PM
habbyguy's Avatar
I conflated the fluid counter with cars I've owned since my Volvo. Good advice above on fluid level / filling.
bm97
Jan 29, 2019 11:12 AM
habbyguy
Oct 2, 2018 07:51 AM
bcolins
2001-2013 model year V70
Mar 24, 2014 09:28 PM
MattS70
Jun 16, 2013 10:52 AM
