V50 Heater intermittent
Have you checked your coolant level? Your car (06 V50) unfortunately does not have a low coolant warning system - and the heater will stop working if it is low on coolant.
BTW there is no heater control valve to reduce hot water flow into the heater core. Heat is controlled with a blend door - (blending warmed with cold air for the desired temp.)
