2006 S40 Heater Core Bypass
Old Aug 26, 2018 | 06:58 PM
OVERLAND's Avatar
Default 2006 S40 Heater Core Bypass
So here I am again, I just finished a head rebuild on my 2006 S40 Which turned out great. After Driving it for a couple miles I noticed my carpets were full of coolant.
I don't have money or time to replace heater core right now. My question is can I bypass the heater core? If so do I just connect the upper heater hose in the engine bay to the lower one? Any help is appreciated. Thanks.
Old Aug 26, 2018 | 07:22 PM
tony1963's Avatar
You will find that the hoses have a coupling to attach to the heater core. To do this right, you are going to have to remove both hoses and attach a bulk bypass hose. There is no issue with bypassing the heater core since the coolant flows through it back to the engine.
Old Aug 26, 2018 | 07:52 PM
OVERLAND's Avatar
Awesome! Thanks for the quick response!
Old Aug 27, 2018 | 09:13 PM
Then again, in the time to fashion a heater core bypass, you could probably repair the heater core issue. My suggestion is to take the time to open up the side of the console to take a look - its quite possible that during your head repair you dislodged or tore the hose from the engine to/from the heater core and simply need to replace the o-rings or hose - some have even used clamps to retain the hose more securely - I doubt if the core would suddenly pop open coincidentally to your recent work.
Old Aug 28, 2018 | 03:25 PM
Hudini's Avatar
Check the o-rings. Probably not the heater core itself.
Old Aug 30, 2018 | 10:12 AM
OVERLAND's Avatar
I did the bypass for the meanwhile, I have not had a chance to dig into the side console. I actually bought the vehicle and it had a small leak on the lower heater hose, which I took too pep-boys to replace ( huge mistake ). A week after it was replaced I blew my head gasket for failure to check the coolant levels. I figured the heater core was the problem all along, or pep-boys newbie wrenchers broke the inlet trying to remove the lower heater hose. Either way, I will be checking it this weekend. Hopefully its an easy fix. Thank you all for the response
Old Aug 30, 2018 | 11:03 AM
myswedishparts's Avatar
Former Sponsor
Four Seasons and Everco make manual shut off valves which allow you to easily turn off water flow and on when you fix the heater core. Most parts stores have them and pretty cheap. MySwedishParts.com
jefflamonica
Dec 10, 2016 07:11 AM
Lima850
Jan 13, 2015 01:53 PM
venture5858
Sep 25, 2010 07:19 PM
TijerasGirl
Apr 27, 2010 01:21 PM
netconcepts
Jul 15, 2008 07:14 AM
