V50 radio doesn't change channels
Old Dec 24, 2013 | 06:58 AM
joh's Avatar
joh
Default V50 radio doesn't change channels
Hi! Just came back from a 50km ride. In the beginning I changed the FM radio station.. just before getting home, I wasn't able to change it anymore. All the presets seem to be the same radio I chose in the beginning of the ride. Turning the tuning **** shows me the regular Hz scale but it doesn't move so I can't change the channels. The **** itself works because I can change bass/mid/treble/balance with it. Imo I also couldnt switch between FM1 FM2 and AM. CD works fine. The only radio I can play also works fine. What could be the problem?
I got a 2005 model V50 with High Performance Sound System.
Thank you in advance!
-edit-
Just an update - now, a couple of hours later, everything seems to be working fine again. Tried to turn off the ignition and even locked the doors before, but didn't help back then. Well, I just hope this won't reoccur.
Btw, nice forum you've got here. Greetings!
S40 in Fla
Nov 7, 2016 04:30 PM
HARU
Mar 16, 2009 11:41 AM
quarterdimenickel
Feb 16, 2008 01:38 PM
degoxin
Jan 9, 2008 02:31 PM
degoxin
Jan 5, 2008 09:48 AM
