V50 wont start
Old Dec 1, 2015 | 02:17 PM
wallrutt's Avatar
Default V50 wont start
My V50 has just had new battery, all has been fine for a few weeks, now when I try and start it all the lights go out and nothing happens.
I have to open bonnet and touch the battery terminals, they spark or crackle and the car will then start?
Any idea whats wrong here?
Old Dec 5, 2015 | 11:05 PM
sounds like you need to retighten your battery cables. Since the battery is new it appears the installer didn't finish the job properly. What I suggest is pull off the positive then the negative, inspect the ends of the cable and use a cleaner brush to score up the inside of the cable terminals, install the positive and tighten then the negative, spray both with a commercial battery post sealer to keep any corrosion/salts build up. If you see any bubbles or melting on the insulation of the cables, consider repairing or replacing.
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
waltonsauto
Feb 1, 2012 10:31 AM
alex57
Sep 28, 2010 06:48 PM
furball3
Jan 28, 2007 03:31 AM
