Vibration: when accelerating at low rpm
Old Oct 24, 2022 | 06:42 PM
Cigil's Avatar
Default Vibration: when accelerating at low rpm
Hello all, could anyone help me to find out why i am having vibration inside the 2010 Volvo V50 on dashboard, steering wheel, accelerating pedal and front seats while accelerating from low speed or going on a uphill road?
Old Oct 24, 2022 | 07:44 PM
habbyguy's Avatar
Motor mount?
Bad CV axle?
Bad front control arm bushing?
Misfire (open up several cans o' worms)?
Bad alignment?
Bad tires?
Worn tie rods?
Worn steering rack?
Bad transmission mount?
That's the answer I can give you with the info you gave us so far.
Old Nov 4, 2022 | 02:58 PM
Cigil's Avatar
Hello habbyguy, thanks for pointing out the possible causes. After inspecting my v50 from a volvo garage, i got to know that, front axle shafts have play and vibration along with boot leaking. Moreover, front control arms are having play too. They suggested to replace front axle shafts and front control arms.
Old Nov 4, 2022 | 03:05 PM
habbyguy's Avatar
Both are quite possible (especially if your car has well over 100,000 miles). If the boots are torn, it's a near certainty that the axles are toast (unless the tears JUST happened).
And the control arms do wear out, causing looseness in the front end. Perhaps the first sign is a sharp(ish) "thump" through the steering wheel when stabbing the brakes a little hard.
S70driver
Sep 8, 2023 09:47 PM
Cigil
Oct 23, 2022 10:10 AM
XC40ITED
Volvo XC40
May 27, 2021 03:19 PM
David Stewart
Aug 1, 2014 10:44 AM
Bowman
Mar 18, 2008 11:18 AM
