Vibration @ 70MPH +
Old Mar 22, 2008 | 09:50 AM
S70driver's Avatar
Default Vibration @ 70MPH +
Ok so I get this vibration in the steering wheel and gas pedal when I go to 70MPH +. What could be causing it?
Bent rim?
Uneven tire wear?
Old Mar 22, 2008 | 10:00 AM
Cambridge Volvo's Avatar
Default RE: Vibration @ 70MPH +
what about the rods, are they okay?
Old Mar 22, 2008 | 10:32 AM
samadkins29's Avatar
70+ is pretty fast, how much vibration? and is it a new problem? When im going 70+ I get some vibration but not tooo much.
Old Mar 22, 2008 | 11:47 AM
S70driver's Avatar
ORIGINAL: samadkins29
70-75 MPH isn't that fast. And sometimes I pass at 80 MPH, but not usually.
1. The vibration is enough to make me not get close to 70, but I still do. It feels weird.
2. No it has been going on for awhile.
Old Mar 22, 2008 | 04:28 PM
Try swapping the tires/rims from front to back and see if it goes away.
Sounds like a tire is out of balance or a belt broke inside the tire.
Old Mar 26, 2008 | 02:53 PM
ocean238's Avatar
does your car pull to one side?
I had that and the car was pulling to one side at 70, then discovered it was a cracked wishbone bush, replaced and the pulling has gone but still vibrating a little bit, going to change my wheels around to see what happens, afterall, it did all start after i have changed the wheels around last time
Old May 30, 2008 | 04:55 PM
s70 2000's Avatar
I have a 2000 S70 GLT (120,000 mls). Same exact problem, but mine starts @ 65. Gets worse @ 70. Steering wheel vibrates, headrests shake.
Had the entire front end checked, tires/wheels visually checked. Can't find the answer.
Old Sep 8, 2023 | 09:47 PM
SGinz's Avatar
Default The Volvo big denial is the problem
Bent rim?
Uneven tire wear?
x
dvfosho6
Aug 25, 2010 07:52 PM
greenbluei
Jun 23, 2010 11:41 AM
ocean238
Apr 17, 2008 06:20 PM
alecw81
Mar 7, 2005 10:47 PM
Macgregorguy
Dec 19, 2004 03:48 PM
