"90,000km service"
"90,000km service"
Hi, Can anyone enlighten me as to what is carried out in the 90,000km or 55,000mile maintanence service.
I called volvo today to get a quote, $915.20 AUD
I would like to attempt this myself, but not sure what the schedule is.
oil filter, fuel filter, oil, sparkies, flush coolant, flush brake fluid, change cabin filter.
did i miss anything if so please fill me in.
Thanks
v70 2.4t
Thanks
v70 2.4t
RE: "90,000km service"
All easy enough to do by yourself. The fuel filter is the hardest part unless you have access to a lift and even then it isn't so bad. The volvos have a goofy little pressure fitting on the fuel lines you need to compress. Oil and filter is fifteen minutes and you can change the cabin filter while the oil drains. Plugs and coolant are also easy. Is half an afternoon of your labor worth saving over 800?
I am sure they have a tool for compressing the fittings. I just used my hands and pulled the nipple end back. It will release itself. Once you get that far, you will understand. The fuel filter is held in by some other crap that you need to remove and loosen. It is no big deal either. The whole thing took about 20 minutes. Make sure you have a pan to collect the gas that is in the filter. If i remember correctly, this whole process will cost you less than 100.
