"burping" engine
Old 10-27-2008, 06:19 PM
mcbalagtas's Avatar
Default "burping" engine
I'm waiting on Timing belt, water pump, thermostat...etc to arrive from FCP. I did some searches, but couldn't find any info on 'burping' the engine after coolant change.
- Anyone have any good tips on how to do this on an XC70?
- how much coolant should I expect to drain?
Old 10-27-2008, 06:25 PM
Default RE: "burping" engine
What year is it?
If it is 98-2000 or older then nothing special to burping. Fill the bottle all the way to the top and drive the car and it should drop to the max line.
If it is a 2001 or newer it usually burps twice. It also usually takes between 6 to 8 miles for it to burp all the way.
Old 10-27-2008, 06:53 PM
mcbalagtas's Avatar
it's a 2001
So once I get TB, WP, thermostat...etc installed. Fill it up and drive around for 8mi...fill up again....and I'm done?...that is easy.
Old 10-27-2008, 08:15 PM
It might burp once while sitting warming up. When it burps you will know it the low coolant light will come on.
tngreg
09-05-2022 07:27 PM
Hyperryd
05-20-2013 12:42 PM
sbrownbw
09-23-2005 09:49 PM
Quick Reply: "burping" engine
