00' V70 cooling fan will not run
Old May 31, 2011 | 09:19 AM
davidhardin8's Avatar
Default 00' V70 cooling fan will not run
I have a 00' v70 xc, the cooling fan will not kick on automatically, I have replaced the fan/motor and a thermostat.....the fan does work when I turn on the AC but then the AC will eventually blow hot air and the car overheats. The temp. gauge never goes above half way but the overflow keeps boiling over. Can anyone please help!!!
Thanks,
David
Old May 31, 2011 | 09:33 AM
bw77's Avatar
Maybe the coolant temp sensor is bad.
http://www.eeuroparts.com/Main/PartD...spx?id=9125463
Old Jul 1, 2011 | 02:50 PM
pschmid's Avatar
Default did you get your car fixed?
I am having the exact same problem! just discovered today. I am planning on see if my fan will run if I send 12 volts directly to it.
did you try the temp sensor? any luck?
thanks!
Peter S
2001 cross country
Old Aug 27, 2011 | 07:12 AM
ALANJACKSON2011's Avatar
Default Same problem, radiator fan not starting
Hello, I also have this problem on my new shape 2001 V70, no radiator fan running, even when air con is on.
Did anybody ever solve this problem?
Mt car gets VERY hot if I drive it four miles and NO OIL PRESSURE warning message is displayed. Any help would be greatly appreciated
Originally Posted by bw77
Old Dec 14, 2011 | 10:51 PM
rograham1's Avatar
Default Did you resolve this problem?
This is a common problem and I was wondering if you had been successful in fixing it. Many would benefit.
Old Jun 23, 2012 | 01:16 PM
seedmanfred's Avatar
Default same for everyone
Sounds like others are having the same issues, did anyone ever figure out the cause and maybe a solution?
Old Jun 24, 2012 | 04:00 AM
Was the question about the cooling fan or the low oil pressure?
Both types of fan Classic two speed and later variable speed are easily tested.
I think we could have a forum just dedicated to V70 low oil pressure. I have two with low oil pressure- one I hope is fixed and will rad test tomorrow.
Old Jan 25, 2022 | 07:53 PM
richardengle's Avatar
mine worked if i ran -12 v, ie reverse voltage
rolandt
Oct 16, 2017 12:24 PM
norasaint
Sep 20, 2012 12:53 AM
MTNBKR
Sep 4, 2009 12:13 PM
elouadj
Jun 25, 2008 07:00 PM
Carbuff
May 26, 2005 12:01 AM
